froggy
Deceided to strip and rebuild the engine today (following on from other threads about low compression) and all went well until it came to removing no.3 & 4's Head. The head was tight on the barrels and when removing, the barrels came away with the head showing what i think is a knackered B&P on No.3. Even worse though is the head is also damaged. 2 of the fins next to the spark plug are cracked and have now fell off.
So if the B&P is knackered then its a full set of B&P's (do i go for stack 1600 or 1641's) and i think its definately going to need a new head but is it going to be cheaper to buy a top end set, and if i go for a top end set shall i just go the whole hog and split the case and change all the bearings?
Damaged Piston?
Barrel
Damaged head
Engine case Numbers
Engine Number (think this was the original number that has been re-stamped onto the case!)
Damaged Piston?
Barrel
Damaged head
Engine case Numbers
