dubdubz
excuse the pun!!!
I have a cab only perforated vinyl headliner that I have successfully attached at the rear in the clasp using the attached cardboard bits.
all good
I have installed the bows and pulled tight to the open windscreen frame, and glued the middle area and secured with clip - I have left the last 12inches or so unglued right now so I can work out the sides........??
this is where I am stumped - totally.
the side is a similar fixing to the rear bit, but I'm guessing its folded and inserted and it then grips?? is there something thats wedged up too? just cannot see what kind of gap between the nody and the gripper strip [this is my new name for it!!] it's about 3-4mm currently
and tools used........I already have one [thankfully repairable and very small] tear and I do not want any more.........
If you have links or pics then all good.....
a virtual beer awaits until Stanford Hall when I'll swap it for a real one. Dubz
all good
