Araon
OK a few quick notes:
1. Carefully read the instructions.
2. Do not manipulate the 1st 4" of the pipe this is the weakest point in the kit. keep it steady and stand / lay it in a place of safety.
3. Fit the bracket in your chosen location (as per your initial order) there are marks on the canister highligting the position of the feed pipe within the can.
4. fit canister to bracket and imediately secure the tubing after the 4" point.
5. Run your tubing and fix with supplied tie wraps but dont exceed the bend radius of 6".
6. Take pictures and forward them to me [email protected] cheers guys and gals.
I can supply some stainless ties for those fitting tubing with the chafegaurd if required, let me know as numbers are restricted. I may have some long stainless ties that fit the diameter of the bottle I'll need to confirm that and numbers if you want to secure within the bracket again let me know.
Any questions pm me/ email me.
