Olly the Ozbus
- Joined
- May 11, 2008
- Messages
- 163
- Reaction score
- 0
Hi folks,
I've just collected my '72 crossover Aussie campmobile which I'm over the moon with and the fun now starts as I have a '68 dormobile interior to go in it :mrgreen: However, I'm a little sure of how to proceed as I'm going to put a ply floor down on the load area which will lift the main unit and seat-base up relative to the boot box- does this mean I should also put the same thickness of ply down in the boot to make sure the bed is level(ish) when extended? Also, if I put the floor to the extreme edges of the load area then I noticed that the central part of the floor is indented so will be a bit lower; is it best to put a couple of batons in for support or will the foil-wrap insulation I'm going to put in do the trick?
Many thanks, I've got a lot of lerarning to do but I can't wait to get stuck in
Cheers,
Olly
Cheers,
Olly
