mcvw
With there being more choice of aftermarket steering wheels for the late bay steering column - in particular this item below (currently advertised on Vzi, and stated as from a series 1 passat).
Can anybody verify that fitting a later column into an earlybay is really as easy as the following text:
Undo the two screws that hold the thin steel cover to the floor at the base of the column, lift that up and you gain access to the rubber UJ that connects it to the box. At the top prise out the hornpush, remove the wheel, unscrew the column switch/s, then remove the three bolts that hold the column support to the dash/front panel, that'll usually give you room to pull the inner column out from under the top housing. It's not rocket science.
If it is that easy, are there any disadvantages of doing so i.e. steering lock no longer works etc?
Has anybody already done/come across this mod - slammedkustom perhaps?
