Fitting Dormobile cab roof liner
thejinx
Mar 30, 2011
1,567
79
swansea
I have no roof liner in the Dormy cab. The windscreen is in and I don't want to take it out. I thought I could attach the liner at the rear of the cab. Secure it with the plastic white strip that covers the front part of the roof aperture then pull it forward securing on the grips above the doors the glue it to the front holding in place with the sun visors and rear view mirror. Any ideas welcome. Cheers
It's definitely supposed to lap under the screen rubber and to be honest, I can't imagine how you would be able to pull it tight enough and then glue it securely if you did it in the order you suggest.
Reversing the procedure (and with the lining tucked under the screen rubber) you could easily pull it tight in stages, secure it along the edge grips and then have a nice neat finish under the white aperture trim. I reckon you'll find that in the long run it will be easier, quicker and better finish this way...
