Front Bra
Matt Maz
Sep 11, 2007
479
Norwich, Norfolk
Do any of you helpful guys know the best place to buy a front bra for my van??
I wanted a checked one with a VW badge on the front.
Is Volksheaven the only place that sells these??
Thank you all
Matt
Other places do em, but have seen different qualities and have found volksheaven the best. Mind you DNA from on here did order one and it turned up to sort to fit :roll: but there was a problem with the template and a new guy, but that has all been sorted now. 8)
Heres mine as an example of their work, creation blue from here has also got one from them and is very happy with it i believe.
I have done a slight mod on it tho, as it is held on the front by aluminium clips cover in leatherette. These have broken over time, so I have sourced some much more flexible aluminum and used wider bits and then recovered with new leatherette. The result is a tighter better fitting bra :shock: :wink:
Yep the Vunderbra at Volksheaven seems to be the popular choice and the way I will be going....
Good quality and service :D
Not actually heard anything bad about them saving the above comment....
nope not yet, nice and firmly in place, a decent uplift always helps tho :wink:
hey shane did you have any trouble getting the bra from them, i have had 2 mates who cancelled their orders as they took so long? 8)
I used Dave at Spirit of the 50's for my last bra. Mine was checkered and the nice thing was that it was lined at the back so it wouldn't scratch the paint work as there are lots of material overlapping as opposed to solid material.
Not sure if Volksheaven do this ?????
Can't comment on delivery as it was a while ago when i last used them, but they were ok. I do remember though that i did call Dave on a weekly basis just to make sure that the delivery date wasn't changing and true to his work it didn't.
I often find this works rather than placing an order and waiting to see if it turns up. The same applied with Creative Engineering who many have problems with, but had none as kept in touch with Dave & Mandy.
I find that you build up a bond and they are less likely to let you down, unlike someone they don't know.
Mike
It was an absolute mare to get the bra out of them to be honest. They just take on too much at once. The quality is excellent however. My one is double-skinned with a soft chamois-like backing to protect the paint.
Yea thats the thing they are great for quality, but not to hot on timing. I am sure they will get there tho. I havent had any troubles with the paint etc due to the bra and i have had it for years 8) just must keep it clean and supple (good cleaner) :wink:
