rustydiver
Right ive been having a clear out so here goes
New Ball joints FEBI JK number J10071 SOLD
New H section JK 11014 £18.00
New RHD N/S Cab floor repair panel JK J11130 £25 SOLD
has slight surface rust where its been sat in the garage.
New Outer sill N/S J10607 £5
Used N/S and O/S front brake backing plates £10 each
Front Brake Callipers, came off my 72 crossover. Needs rebuilding £40 the pair. Provisionally Sold
Spindles and hub off my 72 £50
4 Torsion arms, needs new ball joints £40
Steering arm, of a rhd £25
Panel van conversion glass, came out of my sliding door £20
!/4 light frame, bit of rot on the bottom and glass plus 3/4 glass £45 SOLD
Rear corner was a whole one but cut down just below the swage line £35
Side window lower repair panel £15
!/2 a top hat section £5
Will measure how long and take a pic in the morning.
RH Bumper step. Bit of rust under the rubber, but not much £10sold
Washer bottle with a hole in for an electric pump, dont know what it is off £2
New underfloor centre belly pan in two bits, never been fitted £45
Vw Bilstien Jack £35
LH door lock mechinisim (not the barrel lock), window channel, plastic lock cover and rod. £30
Will get pics tomorrow.
Panel van conversion, sliding door fibreglass cover, needs a good clean. £35. SOLD
Air filter box. Has a hole under the plaster, can be used as spares £5
Collect or meet only on the big and heavy bits.
Should be going to Bristol Volksfest.
Will be at Dubbin in Dorset.
I am in Bridgwater, Somerset.
![P5190219.jpg](https://proxy.imagearchive.com/a60/a6065b106f8e3362c094cf9f68b8cd1b.jpg)
![P5190215.jpg](https://proxy.imagearchive.com/665/665208c3d679ff6c3d40b2346061ef5f.jpg)
![P5190217.jpg](https://proxy.imagearchive.com/90d/90d6caf423fcb97f4d5dbbb4bc700aa1.jpg)
![P5190216.jpg](https://proxy.imagearchive.com/e1b/e1b7191b2a3d7d24e106571585cd8c4a.jpg)
![P5190192.jpg](https://proxy.imagearchive.com/81a/81a972e69f11988c3f7a313116bf8a1b.jpg)
![P5190191.jpg](https://proxy.imagearchive.com/2d1/2d13998aa3a48f87bd55a5d5321a1bde.jpg)
![P5190194.jpg](https://proxy.imagearchive.com/cf0/cf0c4d1e4fd6b1d43c3bae1fd7336596.jpg)
![P5190195.jpg](https://proxy.imagearchive.com/b73/b735bf40e914d7dfb51b7fbdbd0130b3.jpg)
![P5190193.jpg](https://proxy.imagearchive.com/de8/de8405b2e358fe5cc3cf9bb0cfd82ba7.jpg)
![P5190196.jpg](https://proxy.imagearchive.com/423/423e91c50388bb6d187af20b87395d04.jpg)
![P5190197.jpg](https://proxy.imagearchive.com/d62/d626155bcffec9412282f8db7395ddd1.jpg)
![P5190206.jpg](https://proxy.imagearchive.com/216/2168bedcc9d43789ceccbbf77c8a5825.jpg)
![P5190208.jpg](https://proxy.imagearchive.com/177/177ea837dbd9d2894025d62ac7ffabad.jpg)
![P5190209.jpg](https://proxy.imagearchive.com/58e/58ea9f305d45af1917d27f182485c29e.jpg)
![P5190211.jpg](https://proxy.imagearchive.com/cd1/cd1440b17fe7cb4d1f6e99961624bee0.jpg)
![P5190190.jpg](https://proxy.imagearchive.com/7ae/7aed8571e55c5ed8a9518eee390a6751.jpg)
![P5190218.jpg](https://proxy.imagearchive.com/747/74716e49c93d0864a5f05b6027bbd404.jpg)
![P5190199.jpg](https://proxy.imagearchive.com/f5c/f5cbe7521a4bf56cd2d2b1b5fe56420d.jpg)
![P5190198.jpg](https://proxy.imagearchive.com/a20/a2002f010f4f4cb748074cb9095165a6.jpg)
![P5190200.jpg](https://proxy.imagearchive.com/64c/64cc08195efda9a562a928fb9713d133.jpg)
![P5190213.jpg](https://proxy.imagearchive.com/0c6/0c680e4cabe70af6d7d6ad272bf32e4e.jpg)
![P5190212.jpg](https://proxy.imagearchive.com/413/4135484ed70d85b883be4b3e204f17cf.jpg)
![P5190214.jpg](https://proxy.imagearchive.com/1ac/1ac521d2c1196a3876a676a61b57deba.jpg)
![P5190203.jpg](https://proxy.imagearchive.com/656/656d2e3e23ac40cb3a1b844b40f1ec38.jpg)
![P5190207.jpg](https://proxy.imagearchive.com/6ca/6ca3520b0d1cc5c4b4b876e8b84effdf.jpg)
![P5190202.jpg](https://proxy.imagearchive.com/8ab/8ab3d51150d1f9bb3a2283659d8af427.jpg)
![P5190201.jpg](https://proxy.imagearchive.com/af4/af4e728106af16c6b74a7fd022010deb.jpg)
