rustydiver
Right ive been having a clear out so here goes
New Ball joints FEBI JK number J10071 SOLD
New H section JK 11014 £18.00
New RHD N/S Cab floor repair panel JK J11130 £25 SOLD
has slight surface rust where its been sat in the garage.
New Outer sill N/S J10607 £5
Used N/S and O/S front brake backing plates £10 each
Front Brake Callipers, came off my 72 crossover. Needs rebuilding £40 the pair. Provisionally Sold
Spindles and hub off my 72 £50
4 Torsion arms, needs new ball joints £40
Steering arm, of a rhd £25
Panel van conversion glass, came out of my sliding door £20
!/4 light frame, bit of rot on the bottom and glass plus 3/4 glass £45 SOLD
Rear corner was a whole one but cut down just below the swage line £35
Side window lower repair panel £15
!/2 a top hat section £5
Will measure how long and take a pic in the morning.
RH Bumper step. Bit of rust under the rubber, but not much £10sold
Washer bottle with a hole in for an electric pump, dont know what it is off £2
New underfloor centre belly pan in two bits, never been fitted £45
Vw Bilstien Jack £35
LH door lock mechinisim (not the barrel lock), window channel, plastic lock cover and rod. £30
Will get pics tomorrow.
Panel van conversion, sliding door fibreglass cover, needs a good clean. £35. SOLD
Air filter box. Has a hole under the plaster, can be used as spares £5
Collect or meet only on the big and heavy bits.
Should be going to Bristol Volksfest.
Will be at Dubbin in Dorset.
I am in Bridgwater, Somerset.
