Gearbox Mount
5erge
Mar 28, 2009
961
Just outside London
I don't have any supports for my gearbox.
Am I right in saying that I just need a front gearbox mount as the rear is supported by the engine/brace bar?
Des
On mine i have a small plate at the front which holds the front of the box with 2 17mm bolts, then on the rear theres again 2 bolts that hold the bellhousing to the body and obviously the 4 bolts to the engine.
That picture looks to be the right part for the front, but you will also need the small plate that supports those 2 lugs which bolt to the chassis with the 2 17mm bolts!
That is assuming yours has the same mountings as mine
