Hi just wondered if anyone is using this kit? its on offer again at £50 which seems reasonable for what you get.
http://www.halfords.com/motoring-tr...acks-axle-stands/halfords-5-piece-lifting-kit
Just wondering if the 2 tonne capacity is up to the job? My handbook says unlaiden weight of a campmobile is 3228 lbs = 1464kg throw in an extra hundred kilos for any additional items of furniture etc. So in theory they are strong enough as I would only really jack up one end at a time.
Here is the spec anyway, what do you guys think??
The Halfords 5 Piece Lifting Kit has everything you need for car maintenance! The set includes plenty of useful stuff to ensure any lifting you need to do is a piece of cake.
Halfords 5 Piece Lifting Kit Extra Info
2 Tonne Trolley Jack with Short Wheel Base has a lifting range of 14cm to 34cm. Made with a durable welded construction
2 x 2 Tonne Axle Stands have a combined weight capacity of 2 Tonne
Padded Car Creeper allows for comfort whilst carrying out under car maintenance
Wheel Wrench with 17/19mm socket allows for a wheel change
2 x Wheel Chocks allow the vehicle to secured in place
