Well my thanks go to sacramentobay , I followed your method step by step , the only deviation was that I used self tappers instead of pop rivets . I unfortunately didn't take any photos as it all happened so quickly ! I had already put the trim on (from B and Q ) and the ply arrived this afternoon great quality from Beers in Warrington £20 per sheet (1525x1525x3mm ) and £15 delivery to Manchester , so £75 in total for 3 sheets and carried to my door !
So far I have put two pieces in , from the back 48'' to the 1st roof strengthener and then a further 47 1/2 '' to the next roof strengthener , just the front piece to put in the cab area and then either cover strips or if I can locate some plastic H section the same as used to join wardrobe backs I will use that . The width is obviously determined on where you fix the channel so I first made a template and I will use this to check the narrowing at the front and adjust accordingly . The first two pieces were easy to fit .I will let you know how I fair with the front piece .
