Headlining
Linney
Active member
Mar 17, 2014
44
I need to renew the headlining in my 69 tin top , as a newbie to this forum and the risk that this has already been a past topic what are yours views on ply or traditional fabric ? And also the ease of fixing either ?
Wood and fabric are two different methods of fitting. Does your bus have rails running along each side of the inside?....This is where your wooden headliner will slot in. Fitting a fabric headliner is a windows out job and probably new rubber seals. The baltic birch headliner kits are the easiest option.
Hi Linney, I recently fitted a ply headlinging to my '69 tin top as the fabric lining was almost falling off and all split. I didn't have runners down the side of the bus so I improvised, this is how I did mine:
http://my1969vwmicrobus.blogspot.co.uk/2013/05/fitting-my-birch-ply-headlining.html" onclick="window.open(this.href);return false;
It really was easier than I thought it was going to be.
Dave
Thanks chaps my mind is made up I will go for the ply and the trim from B and Q , also follow your great pics and instructions .
This is another on my list of one million things to do :shock: Post lots of pics so we can get around some of the pitfalls whichever way you choose to go :mrgreen:
Ozziedog,,,,,,,,,,,,,,,,I like the material one,,,,,,,,, but I like the wood :roll: ;) :roll:
Well my thanks go to sacramentobay , I followed your method step by step , the only deviation was that I used self tappers instead of pop rivets . I unfortunately didn't take any photos as it all happened so quickly ! I had already put the trim on (from B and Q ) and the ply arrived this afternoon great quality from Beers in Warrington £20 per sheet (1525x1525x3mm ) and £15 delivery to Manchester , so £75 in total for 3 sheets and carried to my door !
So far I have put two pieces in , from the back 48'' to the 1st roof strengthener and then a further 47 1/2 '' to the next roof strengthener , just the front piece to put in the cab area and then either cover strips or if I can locate some plastic H section the same as used to join wardrobe backs I will use that . The width is obviously determined on where you fix the channel so I first made a template and I will use this to check the narrowing at the front and adjust accordingly . The first two pieces were easy to fit .I will let you know how I fair with the front piece .
No its not, loads of people have refitted headliners with windows in situ, do a search on here. I do agree that wood is the easiest option though.
J.
Yes I agree , I will slide the middle section out and put back after fitting the front !
Linney, Glad my blog
http://my1969vwmicrobus.blogspot.co.uk/2013/05/fitting-my-birch-ply-headlining.html" onclick="window.open(this.href);return false; with step-by-step instructions helped you. It really is not as hard as you think eh?
Dave
I enjoyed it ! Your blog made it so that mistakes just didn't happen and the natural finish of the bare ply certainly brightens up the whole bus . Many thanks . Paul
