HarryD
Active member
I have a 1970 bus and one of heater boxes is permanently stuck on.
And even if I could move the flapper valve, since it is a bug motor, the control cables and flapper valve controls do not line up.
Instead of replacing the heat exhangers/flapper valves (they appear to be very expensive), I am thinking I can get two manually operated exhaust cut outs with flapper valves from my local hot rod shop and put them down stream of the VW flappers. I would then lock the VW flappers full open and let the exhaust cut out divert the flow to either my cabin or to the ground.
While not the factory way, it should be less expensive and still be effective.
Any thoughts?
Any thoughts?
