Heater levers removal
Thanks sparkywig will try the small socket, had looked in the Haynes but it just shows him holding the pin.
I used a small pry bar to get enough force on the plastic pins. They're a real sod to do with just your hands.
Sent from my PLK-L01 using Tapatalk
Thanks for the reply georgeyv, did manage to get a screwdriver behind the clip but thought it was going to snap will see if there available and then try again
Socket method works for me as if you use the right size it pushes the pins back together so it can then be removed.
I’m not sure but I’m think I used a 5 or 5.5mm socket (it’s been a while since I had it apart)
Thanks again sparkywig will keep that in mind bet there worse to get back in
