Pretty sure the nipple goes at the bottom, someone will confirm shortly I should know this seeing as i took my bus in for the brakes to be bled this afternnon
If going back together as it left the factory, bleed nipple to the bottom. This is fundamentally wrong, as any hydraulic system should have the bleed screw at the highest point, air can be trapped in the connecting pipe and upper cylinder.
