horn wiring
treacleminer
Jun 21, 2007
53
Ware, Herts
for severeal years my horn has been wired via a separate switch on the dash, thought i would have another lokk at wiring it proprerly. So....... the brown wire through the centre of the column connects to earth ok, where does the other side of the circuit connect to the horn push please
http://www.type2.com/library/electris/sterhor1.htm" onclick="window.open(this.href);return false;
check the first couple of paragrapghs out, i think he had the same probelm as you... horn button on the dash.
does the brown through the column not connect to one side of the horn, 12v to the other side of the horn. there should be a local ground connection at the sterring wheel coupling, or am i wrong here....
