Yes,the alternator does hinge at the 7/8 o'clock position.On the front at this position you should see the end of the bolt,it's a round head which locates in a slot to hold it still.Anyway the actual nut you need to loosen is at the other end of that bolt.It is tricky to see,you'll need a light and a 13mm spanner to loosen it off.You can just get to it enough to undo it.
