lard said:Hi - I replaced all 3 in the standard lamp with "yellow" lights - look very much like OG and you still have the warm rather than cold LED lighting,
I also installed a 1 metre long strip LED in the channel of the roof opening - this is also warm yellow and directs light straight up into the pop-top and reflects of this to light the interior much more evenly than the standard unit - wired an extra feed into the cab light and installed a seperate switch - can take pics you that helps
Johnny said:i have LED tail lights and indicators? they are damn bright, the indicators require a resistor to add load into the circuit or they flash too rapidly as the relay thinks a bulb is out.
I have some festoon LEDs in the two internal lights and again they are at least twice (maybe even 5 times) as bright. Saves on battery as well due to low current and therefore wattage.
ozziedog said:There was a thread somewhere about sorting your dash lights with LEDs, not sure if it was here or vizzi or the lates, but I can rememeber thinking it looked good and you could actually read the instruments,, :shock:
Ozziedog,,,,,,,,, Another on the long list,,,,, of things too do ! :mrgreen: :mrgreen:
Johnny said:ozziedog said:There was a thread somewhere about sorting your dash lights with LEDs, not sure if it was here or vizzi or the lates, but I can rememeber thinking it looked good and you could actually read the instruments,, :shock:
You need a 6mm LED to do this, the holders can be modified to accept LEDs quite easily if you can solder. I've just used a bay dash bulb holder and led in my Dehne fuel gauge from vintage speed. It acts as a map reading light. I should be installing the whole unit tonight.
