Bosswerks T2a rear LED lights - Still available?
here you go!
Email from them below.
I ended up buying most of it they suggested and all good!
Our recommendations for your T2 are as follows:
Pair of Headlight bulbs (hi/lo) - N177051 - These are cold white but have a French Yellow filter that can be easily added and is supplied. We have a 12v warm white option that may fit a T2 but you need to check as space is limited with some of the headlight buckets.
Pair of Stop (brake) bulbs (red) - N177371
4 x Indicator bulbs - N177311 Amber
Pair of Parking bulbs - N177171 Warm White or Cold White
License Plate bulb - N177191 Warm White or Cold White
6 x Instrument bulbs - 177221 - various colours
Interior Light bulb - N177231 - Various options
Indicator Relay - required due to the low load drawn by the LEDs. You also need to rewire the indicator warning light on the dash to be powered directly off the P tab on the flasher and also create an earth for it so it is isolated from the rest of the warning lights. The T2 uses a switched negative system, the LEDs use a switched live hence the need for this change.
The above is a generic T2 list. Some fittings may have been changed over time so please check your vehicle first before making a purchase.
Please note that unless specified (headlights) we sell all items as single units and that VAT will be added at checkout.
I just plugged in the new led flasher relay and all works ok, rears led front standard.
