Lots of parts left from full resto
Haveacamper
Oct 2, 2007
2,068
3
Originally Cardiff - Currently Melbourne
Ok i've got a new list of things that i have to sell. as my other thread has got smaller i went through all my stuff to see what i will need and what i dont. i'm not after any serious money for any of this - i just want rid.
open to all offers on things, or put together a job lot of things and send me an offer. any money is good money. i'm not going to keep hold of this stuff for ever so it will either get chucked or go as a complete job lot soon.
old clip good air box and middle, rubbish top and bottom.
windscreen wiper mechanism, working
handbrake lever and bracket
steering column - the column not the tube
4 stock shocks done less than 6000miles
outer B Pillar new schofields
jacking point new, paint striped and primered - schofields
gear stick with spring
steering colum base
braket from dash to ignition part
rubber handbrake sleeve for base OG
heat riser
drivers Bpillar section
4 earlybay lights - some good, some not so
fresh air vents
master cylinder - non-servo - used
master cylinder -non-servo - NEW
brake reservior and pipe to master cylinder
outrigger - either middle or front need to check
engine lid rubber - good condition
VW status door rubber the expensive type - V good condition
4x hub caps - brazilian
partition plates for seat bulk heads
early drum spindles
disc spindles and discs
cab matt genuine in good condition
fuel tank shelf got hole, but useful if you need a patch
uncut dash from a south african clip.
copied from other for sale thread:
Type 4 Manifold Kits CB performance tall manifolds- new unused - £145
New VDO sensors and gauges need to check what i have - £80 (£120 from JK)
rear trailing arms - a arms to connect to rear torsion tub - £15 each side
rear cast drums for 72 - 5x112PCD
EDIT:
also front bunk
ok guys after a little advice from others i'll put prices up as guidelines but serious, i'm open to offers. the prices dont include postage. if there are lots of people after stuff by bustypes i may be able to pop over to deliver.
old wheels x4 £60.00
1 old wheel £15.00
Engine lid £40.00
VDO sensors and gauges £80.00
old clip £40.00
tailgate £50.00
tailgate glass £10.00
rear corner sections not used £60.00
Type 4 Manifold Kits £145.00
68-70 Spndles £30.00
partion plates x2 £25.00
rear trailing a-arms £15.00
72 drums £10.00
Wheel Adaptors £100.00
windscreen wiper Motor £20.00
handbrake lever and bracket £10.00
steering column not tube £10.00
4 shocks (less than 6000miles) £30.00
outer B Pillar new schofields £5.00
jacking point £5.00
gear stick with spring £5.00
steering colum base £5.00
braket from dash to ignition part £5.00
handbrake sleeve for base OG £10.00
heat riser £5.00
drivers Bpillar section £10.00
4 earlybay lights - good pair £40.00
4 earlybay lights - not so good £20.00
fresh air vents £5.00
master cyl - non-servo - used £10.00
master cyl -non-servo - NEW £40.00
brake reservior and pipe to master cylinder £15.00
outrigger - either middle or front need to check £5.00
engine lid rubber - good condition £10.00
VW status door rubber -V good £20.00
4x hub caps - brazilian £10.00
early drum spindles £30.00
disc spindles and discs £30.00
cab matt genuine in good condition £30.00
fuel tank shelf got hole, £5.00
uncut dash from a south african clip. £70.00
front bunk £20.00
is the mat left or right hand drive? looks one way in one pic and diff in the 2nd? :? dibs if its left please :D
Where abouts are you please. I'd be interested in the clip(if that's another word for the front panel section :oops: ) :)
Bum. Too far for me. Thanks for replying :) (though will be at BigBang and Action, possibly BugJam)
hello have you got bumpers front and back and how much for the front rubber matt and have you got rubbers for sliding door and back tail gate engine and for window prices please cheers chris my e-mail [email protected] and if so when could i pick it all up
no bumpers sorry;
do you mean the front rubber mat in the cab? £30 for the mat;
dont think i have the rubber for slider;
tailgate rubber was shot;
i have engine lid rubber, and i have the window rubbers too, not 100% sure of the condition of the window rubbers but they didnt look perished or letting water in when i removed them.
NaFe
1 old wheel £15.00
Engine lid £40.00
old clip £40.00
tailgate £50.00
72 drums £10.00
jacking point £5.00
heat riser £5.00
4x hub caps - brazilian SOLD
uncut dash from a south african clip. SOLD
front bunk £20.00[/quote]
