TechnicalNut
- Joined
- Feb 4, 2008
- Messages
- 24
- Reaction score
- 0
:| I've just received a quote for the welding on our camper.
I thought I'd share it with you for two reasons:
1). I'd appreciate peoples feedback, especially on the estimated hours per task.
2). So others can learn about restoration costs. Nobody seems to post this info.
Bus History:
The bus was a rust free Californian import in 2000. It's been dry stored for the last two. It's done approx. 10,000 miles since being registered. Originally I thought it needed a rear corner and battery tray. :roll: After lots of paint removal, it appears to require all the usual stuff, arches, sills, lower windscreen support, etc. I'd say it's in a pretty good state compared to many I've seen.
The quote is broken down into two sections, welding and making-good (prep, etch & fill the repaired areas).
Welding: Labour 36 hours @ £30.00 £1,080.00
Make-good: Labour 6 hours @ £30.00 £180.00 (Materials £55)
Total (inc.vat): £1,512.25
Plus, I've priced-up about £400 in repair panels.
All in all, it's going to cost about £2,000, and I'll have a solid shell. :shock: :shock: :!:
I've considered the DIY route, and I don't think the savings will be all that great - when you add up welder, wire, gas, helmet, fuel costs (it's stored 100+ miles from my home!), etc. Plus the time involved in me doing the job. :?
I'd appreciate peoples thoughts, as it's an awful lot of money to source, never mind spend!
The breakdown (some of it):
outer sills, 1.5h
offside rear corner 3h
battery tray 3h (!!)
lower section of side panel 3h
inner & outer lower front panel 3h
lower windscreen support 2h
side window supports 2h
repair old camping accessory holes 2h
front arches ?h
inner rear wheel arches ?h
front seatbelt mounts ?h
one rear seat belt mount ?h
If you got this far , thanks for your time!
Bus History:
outer sills, 1.5h
front arches ?h
