Hi all
First cry for help on here [ex splitty owner]
I have read through old posts to find the answers for myself but haven't found the cure?
Fuel gauge reads full all the time and has occasionally dropped to 3/4 but mostly on full, I have read this is most likely an earth fault.
What's the cure here? do I just run a new wire from the sender to the gauge?
Is it possible to remove the firewall without taking the engine out [splits don't have these]?
Is there a likely area where the existing cable gets snagged/shorts out or can it be anywhere?
Indicators, firstly the stalk doesn't want to hold in position, is there a fix or do I just look for a replacement?
Dash tell tale light only lights for the first flash then lights no more, indicators continue flashing but no tell tale light after the first light?
Is there a fix or obvious fault to check for here?
Many thanks all
Brian
Many thanks all
Brian
