oil pressure
lobie
Sep 8, 2011
1,456
32
swadlincote derbyshire
Year of Your Van(s)
1972
Van Type
Devon
a friend of mine has a bay with a 1640cc engine and twin carbs engine was professionally set up and runs like a dream
today while driving it the oil pressure gauge was reading very high and the bus drove like (there was an HT lead missing) his words
neither of us now owt about engines least of all me
I seem to drive ok but does lack that bit of go when you accelerate, tick over is fine and the oil level is fine also
he was planning to drive it 10miles to MFN Dubdazes on Friday
can anyone help ?
cheers
Lobie
How high? Over 70psi at 4000 rpm when warm?
If it is that high then try removing the two relief valves in the picture below. Your case may only have one but more likely 2.
Some oil may drain out of the case galleries but not all of the sump, ensure that the pistons are removed and cleaned. Then refit them in the correct positions, make sure they move freely in the bores.
Start the engine and check oil pressure again.
