Steve B
Soooo, we've decided to take the plunge, and fit new units etc in the Van.
I've stripped it all out, in preparation, and I'm taking this opportunity to get everything floor wise sorted.
The van was restored around 6 years ago, by the PO, as the units were still in, it looks as though the O/S outriggers, I beams and top hats were left alone (N/S actually ok, but would like to re-do outriggers anyway), because they didn't want to dismantle the kitchen units.
The van itself is pretty solid, but had numerous patches underneath. So I've made a list.
On the N/S, it's just front and middle outriggers/jacking points.
On the O/S, it's all 3 outriggers, and the last 400mm of each I-Beam and top hat. The cargo floor is fine, just with minor holes above said beams etc. Essentially would be ok though.
The vans paintwork is fine, and the sills all look fine and solid. I expect to have to carry out some paintwork repair here and there, but my questions are:
1) how much damage is caused by outrigger renewals.
2) I beam and top hats - can the final 400mm be repaired by welding new in? Will this cause much damage to sills and cargo floor (assuming sills are solid).
3) Which are best ones? Autocraft, Schofields or JK English ones.
4) Can the cargo floor be repaired or spliced in easy enough?
5) Are the 'push on/over' front cross member panels any good? This would certainly tidy it up, as although solid now, it is a patchwork, and I presume this method is the least hassle?
Any advice is appreciated - I understand most of the chassis, but unless you've had it done, or do it yourself, you're never quite sure of the knock-on effects.... apart from having zero cash, as usual!
Thanks.
Thanks.
