found myself with a spare afternoon which is rare so I hit the bus, making some mini brake lines and got to use my new flanger (lol)
Derrick the garage cat was over seeing things
glad I bought a mini pipe bender (lol) :?
it's done the trick, that's full lock
Nice and simple, didn't take long ..... then the fun started, I got the brake fluid out my tool box and there was about a thimble full in it, so I rushed to find somewhere open on good Friday to buy some more at half 3, got some for £6.99 :x poored it in and noticed it was leaking (pretty tight in my garage (not moaning, just painting a picture)) so I got a screw driver and lamp, lay under my bus and it was the pipe from the reservoir to the master cylinder (at the master cylinder) had a prod and this happened but my face was in the way :?
put a new jubilee clip and re filled it. Pissed out again, back under the bus, found a split in the pipe, had to cut an inch off it, which made it a little tight, but still usable.
struggled like hell getting the pipe over the nipple (lol) on the master cylinder in such confined space, I filled a jar with boiling water to dip the end of the pipe in (lol) to soften it up to push it over the nipple (lol) simplez
Now then, have you ever tried lie'in on your back, with your legs crossed, with a chassis leg a inch above your chin, with your hands above your with a jar of boiling water in one hand and 2 fingers trying to grip a pipe covered in brake fluid ......... so that will be burnt hand to add to the brake fluid in my mouth and ear .... I decided to call it a day with that and get some more pipe as soon as I can.
while i was working on the front end there's a bumper bold I can't shift. So while i was under there I got my blowlamp and heated the bolt until it was glowing, put the blow lamp down and grabbed my brake bar, but couldn't see the bolt very well so I moved my head, straight onto the blowlamp nozzle, burning my head and making a nice little bald patch
I also smacked my forehead on the chassis when I jumped. I was at that point, where i unplugged everything, turned the light off, locked up and went and got some beers. ******* bus
