had a productive day today
stripped, cleaned, painted, greased and new cylinders
started cutting out some rot and could smell burning wood :? time for a unplanned interior strip out
looks like the previous US own was not only a scruffy ******
but a bit of a Casanova :shock:
it was obviously the glasses 8) angelos epithemiou
Arch was blissfully unaware
he then set about rounding off some screw heads
finished off the welding
there were other bits but you get the gist of it, gave the inside a sweep out (lol)
I now have all the column, barrel/key, new ignition switch, a new indicator switch (massive thanks to Stu61. Actual top bloke!!!!!!)
now this is happening
stocked, to do: new master cylinder, sort the cut out loom (which I found when I stripped the interior
) bleed brakes, go through electrics and switch's, steering column, ignition etc.
