Ply headlining question
If your not too fussy about og stuff,I used 10mm plaster board edge bead from B&Q
Screw it in place with self tapping panhead screws,then press the trim until its closed up to about half its size.
And looks like this fitted
Went through same prob as you ,found the most perfect j trim at local Howdens Kitchen branch,its actually a laminate floor end trim but looks and fits fantastic,almost looks OG .....
gooding aluminium can supply j trim and h trim for the sides and the centre joins.....minimum order though :?
or hunt around cause og does come up from time to time
ste
