Took the Bus for a short spin today and a horrific noise started coming from the back, I stopped and checked the engine bay fearing the worst!...
Black metal dust everywhere and sparks coming from the top fan belt pulley. It seems to have been grinding against the Dynamo casing. Is there a quick fix for this? I.e: a washer to increase the gap?
I took the outer pulley and fan belt off and had a look, replaced a spacer "the big thin washers that adjust the fan belt tension" with a spare I had lying around as it had sheared, but couldn't manage to take the second part of the pulley off to investigate further.(Nut with a tiny pin in the middle"
It is still very close and rubbing slightly but no where near as bad as it was.
I've read a lot of people grind the pulleys as this is a known issue but I haven't got the tools to do this.
Would a simple washer create enough space to prevent the grinding? If so any advice would be much appreciated as I'd like piece of mind before driving to Busfest with the wife and kids!
