davebug
How tight should these little buggers be ?
mike.s said:yep - you definitely need more than a standard ratchett - get yourself a scaffold bar!!
ianscooby said:mike.s said:yep - you definitely need more than a standard ratchett - get yourself a scaffold bar!!
. If it's make a noise check you haven't damaged the drum
When you say happened to yours ,what happened,and what did you do mate ?Grazy said:ianscooby said:mike.s said:yep - you definitely need more than a standard ratchett - get yourself a scaffold bar!!
Think this has happened to mine![]()
