Rear wheel bearing replacement...
Fraggle
Nov 22, 2006
520
Fraggle Rock (Portland), Dorset
Never done one so how bad is it??
Rear brakes all stripped out at the mo so opportune moment really.
Oh and if someone has a pic of a rear brake set up that would be brill so I can compare what I've got.
Cheers 8)
Drop the drive shaft off, knock the stub axle out & pull the dust cap out. There is a circlip in there that is tricky to get out, but then it's straight forward. There is a spacer between the 2 bearings, so don't forget to put it back in.
Cracked it yesturday!! Did both sides on my bus and it has cured the brake pedal judder I was experiencing when braking.
Thanks pete for the advice it was exactly as you said and getting off the circlips was a bit of a bugger!
Well chuffed! :p
