Removing door check strap to fit seals?
lisavx
Jul 5, 2016
190
Liverpool, UK
Can anyone help with how to remove the door check strap to allow me to fit the new seals? I have already removed the door cards and can see there are 2 screws holding the bracket inside the door but wondered if there's a more obvious (i.e easier!) way? Cheers [emoji106]
I did as above - IIRC there's a small circlip that I removed from the pin, then drift the pin out. Was a 5 min job including 3 mins of trying to find the circlip I'd dropped. Once the pin is out you can seperate the check strap and get the seal on easily.
