Repairing steels
Goldensyrup
Sep 21, 2013
208
One of my steels is quite badly pitted on the inside. Not crazy but not sure if it will hold air or not?
What can I do to the wheel to sort this problem?
The steel used on wheels is usually a good few mm thick, unless the pitting is really bad I cannot imagine it would affect the structural strength of the wheel or its ability to hold air.
However, I would probably take a knot wire brush to it to remove any corrosion, then assess the material which is left. That would also give you a clean base to repaint if they look OK.
Post some photos up, it might help?
Sent from my C55 using Tapatalk
WHS ^^
If it's a '71 onwards van (5x112mm stud pattern) then the wheels are so common I wouldn't waste your time trying to repair anything especially crusty...
The wheels are 15" Splity steels 5x205's
After sandblasting there not liking too bad, I've gave them a couple of coats of hammerite on the inside and will try on a tyre and see.
The dude I bought them from said they held air when he had them so can't see why they won't work
