Replacing a dashboard light bulb - how?
Tezzah
Sep 17, 2009
949
Waterlooville, Hampshire
Hi all.
I'm guessing it's just a case of removing the heater knobs and unscrewing the dash to gain access to the dash board bulb, or is it a bit more technical than that? :shock:
Tezzah said:
Hi all.
Unscrew the cable from the back of the speedo as well ;)
Make sure you turn off ignition/lights first - sounds daft but the back of the instrument panel is live and a screwdriver on this and brushed against the metal of the dash will blow a fuse :oops: - I wanted to test it before putting back in and managed to turn a 5 minute job into a fault finding exercise :D
I was pleased with it, and only cost a few quid in parts from maplins - looks more blue in the flesh!
Like that dood! got any pics of the build up/ swapping to LEDs? :mrgreen:
Sorry mate no, it was a kind of, "I'll give it a go to see if it works" one Sunday afternoon - and it did!
These are the LED's that I used from Maplins, I cut them up to rows of 4 (from memory), 2 rows around the speedo and one around the fuel guage. Wired the feed from the existing bulbs, which I did leave in place - just in case!
Quite a straightforward job if you are handy with a soldering iron, and easy with the guages out and on a bench.
The dimmer works too :)
http://www.maplin.co.uk/Module.aspx?ModuleNo=218015" onclick="window.open(this.href);return false;
I believe you can get direct replacement LEDs for the stock bulb fittings, haveacamper got some for his Porsche gauges but think they are similar fittings - will get him to post up some more info & where he got them from.
