junglefacejake
Looking for the best way to remove a re-spray and reveal the OG paint without damaging it. Any help, advice, hints or tips greatly received
Hoping to expose "light grey"!Grazy said:Mr Muscle oven cleaner ! :shock: ( so ive been told )
junglefacejake said:Hoping to expose "light grey"!Grazy said:Mr Muscle oven cleaner ! :shock: ( so ive been told )
Thanks for the suggestions so far.
If there are any more proven techniques I would like to hear them.
New project? Any pics? 8)junglefacejake said:Looking for the best way to remove a re-spray and reveal the OG paint without damaging it. Any help, advice, hints or tips greatly received
All in good time George all in good timegvee said:New project? Any pics? 8)junglefacejake said:Looking for the best way to remove a re-spray and reveal the OG paint without damaging it. Any help, advice, hints or tips greatly received
So nitro morse is ok to use? Worried that it would attack the og paint?Carlos said:Hi, I did about 200 hours+ removing 2k paint and about 3 layers of other paint to get to signwritten paint - I like the result but wouldn't rush to doing it again! annoyingly the rules changed on what could be in 'stuff' a couple of years back and a lot of good products for getting paint off became crap - no nonence graffiti remover used to be brilliant.. after the changes and trying pretty much everything I could lay my hands on I found the traditional method of using farecle G3 and G6 to work really well without risk of going too far. Nitromors paint stripper is nowhere near as good as it used to be but does still work, eventually, just have to make sure you have meths to and to nutrilise (?) it once its taken the bit of paint off you're working on - good with 0000 grade wire wool too.
if I had to do it all again though id simply arm myself with a scraper (type that take a stanley blade) to get any loose/thick paint off, a big tub of farecle, loads of rags and some 0000 grade wire wool.
Hope this helps
Carl.
