seat belt bolts - thread size?
dubdubz
Jul 10, 2007
2,549
5
Peterborough mainly never Cornwall
Hi
hopefully a quicky the seatbelt mounting bolts in the rear of a bay - what size are they it looks like m12x1.5 but I ran a die down an old one and it didn't seem quite right...close but not exact?
the original in the rear arch captive nut for the lower belt mounting point.........will this also be the above size ie same as the under window bolt size.........??
confoosed
If you PM Noddy I have this incling that its the business hes in... either sells /installs or makes restraints
Regarding the rear arch mount - unless you lucky/have a rust free import this will be rusted out and need replacing. VW cunningly design the original as the perfect salt, crud and moisture trap. I ended up with a perfect rectangular hole wher the mount used to be when I attempted the same..
If this looks familiar be prepard to break-outthe welder..
James
