Sliding door
Dan72
Aug 2, 2008
57
Gloucester
My sliding door does not pop open. Have to pull on the louvered window to get it to release. Im assuming something is missing??
Anyone ideas?? I know nowt about these
Could be that the spring loaded part(rearmost centre mount) needslubing n working free.Its the u shaped bracket the roler attaches to that is spring loaded i think.Start with wd40 then regularly oil. also oil upper,lower and centre runners(nothing to do with your problem but makes your door glide rather than slide :wink: .
If oiling the u shape doesnt fix it you will have to pull the inner panel off to see if there are any probs inside.
Page form a hand book explaining where to lube.
Johnny said:
graphite powder in the lock cylinders.. theres a handy tip 8)
My old man was a locksmith and said to never put oil in locks, it attracts dirt and grit and ruins the barrel eventually, always use graphite powder. If you have none, just rub a pencil all over your key a few times. :D
