Sooty back?
tsunamivw
Dec 12, 2009
142
Leyland Lancashire
Hi All
Just back from a nice jaunt and the back of my westy is again covered in black marks, I'm running a 1600 with twin carbs and it backfires when you take your foot off, we've heckled the timing and tapped the tappets, is the mix too rich?
Ideas welcome
Check for air leaks on the carb(s) and particularly on the exhaust.
Hi!
If one of the pre heat pipes has rusted through, this will make it backfire, mine did this. The pipes are the thinner ones on the inlet manifold that go to the top of the exhaust, on a stock set up anyway.
Or a oil leak will splat the back, pushrod tubes, rocker covers or crank seal which will leak between the engine and gearbox join, oil will splash up the back like this too.
As already mentioned, a air leak somewhere, inlet or exhaust (pre heat pipes)
HTH
Cheers,
Alistair
I covered the exhaust while it was running as suggested and it didn't seem to change the engine note, is that an air leak? If it is apart from the manifold where should I be looking? Its a 1.6 twin carb with a stainless from Bluebird
