When I removed my spring plates I stuck a trolley jack underneath and as I pulled them over the lip I expected there to be massive tension. When I let my jack down the plate only moved down about 20mm just over the lip! I thought these would move about 45degrees or something!? My only thought was that I may have pulled the whole torsion bar out by accident. I did try and hammer it back in slowly as I was pulling the spring plate off.
Is this the normal amount of tension on a stock setup?
The photo below shows what the new adjustable plate looks like before I put it back over the lip. This is where the original sat when I pulled it over the lip and took the jack down.
Thanks for any pointers!
