I've had these parts sat on a shelf since changing to discs a few years ago.
Front drums and shoes - these were new at the end of 2015 and we're used for around 6k miles. Drums are the late split type with the correct seal to fit an early bay. Includes grease caps, bearings and shoes. £150
Rear backing plates and cylinders - these are from an October 67 bay, I think they may be the originals but are very solid. To me they also look the same as the late split version. The very early ones are different to the later 68, I'm not 100% sure of what changed but think they are interchangeable. Includes the cylinders (were fine when removed) and the bolts/spring washers that I could find. Only one side has bleed nipples. £80
Will also take £220 for the lot
Can probably post at cost if I can find a strong enough box. Collection welcome from Lincoln and I travel to Gloucester weekly so can probably drop off en-route.
