stearing box arm removal
ricvw
Feb 4, 2008
90
Lancs
has any one got any tips i have sprayed it with penatrating oil the last few days and got a puller from work but it still wont go is it going to need a bit of heat. any help greatly recived
bugger of a job
I had this problem i used a lorry ball joint splitter (hinge type)loads of welly on it went with a big bang.As for heat the only problem is it will distroy the seal but may be the only way
I used a hydraulic puller that I managed to borrow. Also went off like a gun
when it eventually gave way - nearly sh!t myself..
Try your local friendly garage or you may be able to hire one.
James
Similar story here. After bending/distorting a few different puller types I squeezed in the heaviest duty bearing seperator I could.
It took a lot of force to get the bugger to shift - the difficulty was keeping everything square whilst winding on the load.
