Steering column bush
Thanks I just pulled my steering apart and managed to get it out.
Mycha I understand fully now what you mean about fitting a lower bush, job for tomorrow lunchtime is making some bushes :D
Okeey cool ;) i’ve you can make a spare one i’m interested 8) alway’s good to have a back-up one :p
If delrin is ok the I thing I have enough material for 6 maybe more. I used delrin for my beam bushes so if it's good for that it'll be fine for the steering.
I'll let you know how I get on.
:anim_19:
So i have made some, but sorry guys i had an accident. I had a look about and have some nylon if thats ok for you i will make some out of that.
Mycha i had a thought about the bottom bush and made the OD smaller to fit the lower part of the tube.
I should still have both of your addresses so i'll stick them in the post.
Hello,
Nylon is ok for me, smart to do a small one for the bottom bush, very nice if you can make me such a set :D
Will pm you my adress. THANKS
I'll test fit mine first and let you know Whistler, shouldnt be a problem. I may buy some material and knock up a load as the bronze ones at Bluebird are stupidly expensive at £20 each.
That would be great! If there is a cheaper alternative, it can only be a good thing! And I'd prefer to put the money in the pockets of a forum member anyway.
