bluenose
Hi all,
I've took my steering column apart to change the ignition housing and indicator switch but now it's stripped the bearing doesn't look right to me.
The bit on the right was fit in the top of the column tube and the bit on the left was sat inside it and then the spring on top (the spring that I've now lost :x )
I would have thought if it was a bearing it would of had some ball bearings or something in it. The bit on the left is just a sloppy fit inside the bit on the right.
I've searched everywhere but I can't find a pic of what an early bay one should look like, only splitty and late bay parts seem available for this.
Also there was some rubber insulating sleeve in there which has disintegrated.
bearing by bluenose1982, on Flickr
