I have a spare stock 1600cc twin port long block engine up for grabs.
I have fitted a new flywheel oil seal as it was a bit weepy. It has a 200mm flywheel. I set the valves before doing a compression test. There is 130psi on all 4 cylinders which is very good. It runs very quiet with no knocks or rattles. There is no excess end float.
It will fit a Beetle or splitty, but you would need a case adapter bracket to fit to a bay.
I am looking for £250. Located in Aldershot, Hants. Collection or local delivery. 07970 540757
I have the tinware which will be back from powder coating next week. It is being done gloss black. I would sell this for £195.
I can make the engine up complete with the fresh tin, powder coated silver stock manifold, carb, 55 amp int reg alternator, 009 dizzy, good beetle exhaust & heat exchangers for £595 with new gaskets ready to run. You can hear/see it run on the bench & I can even help with fitting.
