Been doing a lot of reading on timing, as finally wanted to get around to checking that all is well on our bus. Maybe I have now done too much reading as I'm a little confused at the results!
So I'm pretty sure I have a single vacuum advance with electronic ignition. With the vac line connected, I'm getting what looks to be about 11 or 12 degrees of advance at idle. Setting the gun to 30 degrees, as the revs increase, the TDC mark comes very quickly into view and lines up - but seems to advance well before 3000rpm. It doesn't move from this point as revs increase though, so hopefully this is a good thing.
Just wanted some pointers really, slightly concerned by the high advance at idle, when I'd assume it shouldn't be advancing at all at this point. I don't have a rev counter, so I guess the issue could be that it is idling a little too high.
Really shouldn't have started tinkering before MOT day tomorrow!
