mjknight71
looking to buy some heads (2nd hand), I am collecting parts for a engine build that may or may not happen.
So
Standard VW heads are 35.5 inlet, 32x8 exhaust can these be machined to larger valve sizes? Or should I just buy the larger valve VW Mexico ones 39 x 32 as it is cheaper than machining? If I go 1776 they would have to go to the machine shop anyway :?
..........or just looking at new prices the Empi the 40 x 35 (cut for 1776) ones are only £30-£50 more each than the 39 x 32's 1600 ones :? :? :?
Does the smaller valve size choke a 1776?
What will be easiest to get and give a good balanced engine?
So
