Trackrods and Master Cylinder
tsw
Mar 18, 2015
16
Would be grateful if anyone could answer the following:
What is the length of the shaft of each trackrod to suit a 3" narrowed beam? I'm cutting down some standard adjustable ones. They are obviously not parallel to the beam, so it is sadly not 1.5" off per side (I believe).
Is it possible to get hold of a seal kit for the master cylinder for a LHD 1971 with sevo?
You're right, they're not parallel, but they are so close to being parallel that 1.5" off each side will be fine. There is plenty of thread on each track rod end to allow them to safely clamp up. If you're really fussed, lop only 1" off each side, as long as you have more than 1" of thread showing on each track rod end currently.
Sorry, meant to say 0.5" of thread currently showing.
