Hi you gurus and tricky if you are out there,
I bought a oil bath air filter the one with the spring loaded wax filled thermostat unfortunately I havent been able to source all that bit, so today at harewood I bought a vacuum operated one as in the picture
Can anyone point me in the direction of information how I connect the two vacuum pipes out of the top I assume they must connect to the carb to create the vacuum?
I think I am begiining to understand it more following this thread http://www.volkszone.com/VZi/showthread.php?t=675928" onclick="window.open(this.href);return false;
But - the vacuum comes of the manifold which i have now changed to a performance manifold that doesn't have the vacuum pipe DOH! So other than getting a fitting for the manifold can I use the vacuum of the extra pipe coming from my 34 pict 3 ?? Alsooo, on the thermostat it has a brass tube and a plastic tumbe anyone know which connects to which on drawings i have seen the plastic tube connects to the carb/manifold where logic I would have thought that connects to the carb/manifold?
