what goes here???????????
crede999
Feb 10, 2009
1,668
in the large hole ??????? any ideas
just got back from rtts in a monsoon all the way home , there was water getting into the engine bay and this is the only way in besides air intakes , what goes there , who sells the parts?
are they surposed to be there?
regards
chris
Looks like a rear offside inner wheel arch and there shouldn't be a hole there...unless a previous owner had some reason for putting the hole there (air-intake scoop to engine bay maybe?)
thanks for the reply
mmm interesting theres one the other side too ?
i think there og as heres a pic before i repainted the van !!
crede999 said:
what goes here??????????? in the large hole ??????? any ideas
Nothing - it should be metal. OG holes are stamped - that looks cut to me.
If you dont want to weld it up then you will need to make or find a suitable bung (large blanking grommet?) since the alternative is to have muck and water enter the engine bay and worse, in dusty conditions, a lot of dust getting in which will also clog your air filter.
The fan will suck any dust raised by the vehicle into the engine compartment. Bad idea. Thats why the air intakes are high up and theres a rubber seal going round the engine lid.
If you dont want to weld it up then you will need to make or find a suitable bung since (large blanking grommet?) the alternative is to have muck and water enter the engine bay and worse, in dusty conditions, a lot of dust getting in which will also clog your air filter.
thanks for the replys , ive ordered two rubber blank grommets for £1.62 so that should take care of it thanks
again
chris
