rustydiver
I'm going to fit one to the pick up, What have people fitted and where from?
Geeze said:the mocal ones are nice, much better than the bag of pipes jobs in shrink wrap you see at shows.
that said, most important thing is to make sure it's in the airflow, not nailed to the underside of the floor by the gearbox in stale air.
for a cheap option, a mate runs a second stock oil cooler on a pipe run into the arch airflow and noticeably took the heat out of the motor when running fully loaded in summer 8)[/quote
any cooler fitted will help cool the oil,if you can get it in some good airflow all the better.
for my self i will need to use a fan because i am limited to where i can fit the cooler.
alex4057 said:http://www.vwheritage.com/vw_spares_Oil-cooler-kit-T1-2-72-plate_act_shop.product_pID_95875_lang_EN_country_GB.htm
? :mrgreen:
meowdmucker said:Just to throw a spanner in the works so to speak, do you need a remote cooler? I fitted a 2110 with twin 44's 2 years ago. It has full flow oil filter, a deep sump and very well sealed tin wear. I have a vdo oil temp gauge and even long journeys doing 70mph on the motorway the temp never gets beyond 103/105. Mostly on A roads it remains between 90 and 100. I was going to fit an external cooler but thought I'd give it a try without and have no intentions of doing so now especially as we don't get many hot days in the year!! What do others think?
Trikky2 said:If you fit a temperature gauge make sure the thing is accurate. Ive seen some that read 20C out.
meowdmucker said:Put the gauge in boiling water to see if it's accurate. Takes all the worry away then. If not send it back!
Trikky2 said:meowdmucker said:Put the gauge in boiling water to see if it's accurate. Takes all the worry away then. If not send it back!
(He means the sender) :lol:
